smic piping woes
bigjangin
458
Sep 1, 2003
Seattle, Washington
heres the situation: installed a supra smic, install was a bit of a pain in the butt, but when it was in there it felt good. My car is not lowered and will not be lowered so the smic sits a little lower than most people who do this mod, but it still has plenty of clearance.
Anyways, back to the topic. With the supra smic, I also received all the stock supra piping, which is considerable larger than our stock piping. I used a 2.5"-2" reducre on the licp, then I rigged something up for the upper intercooler piping. We cut off the stock dsm pipiing from the smic to right before the bov. We then ran our supra piping up to this point. Here is the problem:
We measured wrong, and the stock uicp at the bov is just a tad smaller than the supra piping. Its JUST enough so that you cant clamp well. We tried various methods of rigging it, but the piping always blows off after a few runs. My latest solution was this: I took some of the stock rubber piping, and got it to BARELY stretch onto the stock uicp(as a sort of big rubber washer). This now made it possible for me to clamp the supra piping to my stock uicp. Will this work well, and since the stock rubber piping has that mesh stuff on it, will this cause problems? I will try to get pictures soon as well. Thanks.
I would think that would create a leak?
Even if it doesn't leak I'm pretty sure that it isn't holding pressure all that well. Do a leak test and see if it holds.
Jake
problem fixed. We used some of the stock piping as a spacer so it would clamp. thanks for the replies.
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
  • For sale tons of 2G parts
    cleaning out storage
  • Wanted 1g 7bolt na ofh
    ISO a 1g 7bolt na oil filter housing. I attached pictures for reference
    • Creuz
