13g wastegate actuator on 14b??
I know this is an old thread, but I am also very curious in this.
The 13g actuator is the same as the 14b. The coolant lines won't work, and you need a new oil feed line. The oil return can be used, but it is a little short.
pickens said:
Will a 13g wastegate actuator fit on a 14b. Also what about the oil and water lines, would they be the same also.
The 13g actuator will bolt up fine, but i believe the spring is somewhat softer in it than the 14b is. The lines for the turbo however will be different :talon:
  • For sale 1g 1G FWD rear suspension Drag lift setup
    This is for a 1G FWD. A drag suspension air lift kit. In the later 90s. Believe it was Dejon...
    • sanmantsi72
    • El_marto
