23109 N8
- May 3, 2003
Ok, I hope this is the right section for this.
I have a 91 GSX with the following mods:
- open element filter
- big 16g ported/clipped 10deg/ 34mm wastegate (TRE)
- custom PWR FMIC and 2 1/2" piping
- Ported 1g intake manifold
- Greddy Type R BOV
- Blitz Dual SBC boost cont
- Blitz FATT TT
- Boost and EGT Guages
- upgraded fuel pump with rewire
- 2g ported exh. manifold
- Evo 2 1/2" PORTED O2
- full 3" DP and exhaust w/ no cat
I am looking for advise on fuel and management...
I am about to order new fuel injectors...
I have a S-AFC (new not installed yet)
I have not modified the stock MAF
I do have a custom intake with the electronics mounted outside the intake tube, which supposedly will flow better.
the current plan was to install S-AFC with 625cc injectors and possibly remove the lower honeycomb. and tmo eprom mods.
I keep reading of different options (like vpc's, GM MAF's, modded MAF's, 2g MAF's, etc) and need input
I don't plan to go with high dollar stand-alone.
here are some pics so you know i am not b.s.'n:
(just got back from paint)
- Greddy Type R BOV
- Blitz FATT TT
Leon has gone faster then you will ever go and has done more in his dsm then Most. How dare you question his suggestions. You have no first had experience with anything being discussed. Quit magazine racing and add something relevant to this thread or simply BE OUT. Leon suggests the HKS VPC, and i agree it simply works nuff said.
