G-Ell
- 136
- Jul 10, 2002
Lehigh Valley,
Pennsylvania
note: This is for 1G cars only!
Total cost: $5.00
What you need: 2.0 NT tachometer from the junk yard (7000 rpm red line) + a philips screwdriver.
How: Mark has good step-by-step instructions on his site for getting the cluster out and apart. http://www.ppg.trends.ca/vfaq_1stgen.htm Follow the steps till you get the black cover off (don't remove the needles or faces). Then turn the cluster around. Remove the 7 circled screws shown on the attached picture. The two circled in blue aren't on the NT clusters, so you won't need them anymore. The turbo tach + boost gauge come out as one, and you can just put the NT tach in it's place. Screw it back on. That's it! Reassemble everything and start your car.
Why: In my car, I noticed how inaccurate the stock turbo tach was. I'd be out doing runs, shifting at 7 grand (according to the tach), and looking at RPM peak recall on the SAFC to see I was actually shifting around 6550 rpm. Even traveling down the highway say around 3500 it would only be about 3250 on the SAFC. It seemed the higher the rpm's, the more off it was. I thought maybe the gauge was going bad, so I went to the junk yard to get a new one. Unfortunately, there weren't any. There were lots of NT's though, so I figured, why not.
Results: Honestly, that POS thing they call a boost gauge is useless, and I'm never going to get the TMO mods for that gauge. I like the NT tach better because there's more space between the numbers so it's easier to read. Most importantly, 7 grand on the tach, is 7 grand on the SAFC too.
Total cost: $5.00
OH WAIT!! you're one of the "COOL" guys with the 12" tach on the passenger side of you dash that lists every number ;O)
