MNGSX
- 2,533
- 25
- Mar 30, 2003
Bloomington,
Minnesota
I was looking at autspeeds DIY boost control articles.
Bottom has all three links
http://www.autospeed.com.au/A_0685/cms/article.html
I looked at all the different systems.
I came up with someting to do with the BCS restricor after you remove it from the solinoid.
Stick it inside the end of the T fiting that attaches to the line from the compressor port.
That is like our factory system with the exception of the restrictor between the turbo and the T. Also we have a solenoid between the bleed outlet and the counted side of the MAF.
Just mentally draw that in there.
From
http://www.autospeed.com.au/cms/article.html?&A=0096
By moving the restrictor from the BCS to the T inlet from the turbo does two things.
Eliminates the restriction at the BCS which allows air to bleed out faster.. Less pressure on the wastgate actuator.
It also creates a restriction at the pressure inlet to the system. Not only can pressure get out easier but there is less air trying to get in there.
This will allow the wastgate to close faster on shifts and raise the boost pressure
From
This diagram shows a typical wastegate bleed. A T-piece is inserted in the wastegate hose and air is bled out. One of the problems with taking this approach is that often a lot of air needs to be bled from the line before the wastegate actually sees a lower pressure. That's because there is an awful lot of air available from the turbo - bleeding off just a bit often makes little difference to the pressure seen by the wastegate actuator.
The way to overcome this problem is to insert a restriction before the bleed, as has been done here. This way, the bleed needs to flow only a small amount of air to make a large difference to the pressure seen by the wastegate diaphragm. Introducing the restriction is fundamental to the way in which this system works. The insertion of the restrictor also adds a measure of wastegate delay - the wastegate doesn't start to open until all the hosing the other side of the restriction is filled with pressurised air.
