gritsak
- 442
- Dec 31, 2002
im getting ready to put my motor together this week and i need some help first...ive already got a new factory metal headgasket that i was planning on using in my built motor, but after reading a couple threads ive heard a lot of praise on the cometic.
ide rather get the right gasket now rather then have problems later...my setup is a crower/ross combo with an o-ringed block, and arp head studs.
ive got a t3/60-1 turbo and im planning on running it to around 25-30psi at the track with race gas (or on the streets racing).
most people seem to have a lot of good luck with the cometic, ide plan on getting their HP version with the fire rings i guess. so anyways, is there anyone that runs high horsepower and boost on the factory metal with no problems? the head will be resurfaced and the block is fine so it should be a good sealing surface.
and also why im on the topic..is there any reccomendations or tips on preperation for the headgasket install to get the best seal?
TIA
TIA
Hope that helps.
