tsi_turboawd
- 474
- Jun 20, 2002
Las Vegas,
Nevada
Now with my motor apart rebuilding the bottom end because i melted a piston
I am planning on getting a ported small 16G 7cm housing. Also i just picked up a ported 2G exhaust manifold and getting ARP head studs as my addition with the rebuild. How much boost should I run safely on the street with stock 450cc injectors and 255lph fuel pump?
Id like to see the setup of those with small 16g and stock injectors.
dont wanna melt another piston again
I am planning on getting a ported small 16G 7cm housing. Also i just picked up a ported 2G exhaust manifold and getting ARP head studs as my addition with the rebuild. How much boost should I run safely on the street with stock 450cc injectors and 255lph fuel pump? Id like to see the setup of those with small 16g and stock injectors.
. but whatever makes the car happier and faster is good. Ill play around with the boost setting and read my knocks.
