4wd-Eclipse
- 380
- 3
- Aug 26, 2002
Oman, Muscat,
Asia
I need to know if 0.003" piston to cylinder clearance as recommended in the details sheet is good for 6bolt engine running 22 psi or should it be bigger then that
Originally posted by 4wd-Eclipse
I need to know if 0.003" piston to cylinder clearance as recommended in the details sheet is good for 6bolt engine running 22 psi or should it be bigger then that![]()
