Walbro 255 install kit?
pinky
71
Oct 6, 2002
St.Paul, Minnesota
hey guys, i just have a quick ?. i purchased a used Walbro 255 but it has no wires with it, just the pump...so where can i get just the install kit or the wires?
thanx for the help
pinky
Just see if you can order a install kit; you should be able to find one on the net. The vendor where you bought your pump should be able to supply you with the kit.
Sorry, I just reread your post and saw that you have a used pump. If you know how to wire it then just buy some wire and and wire it up your self; you dont need much.
yeah spend like 2 dollars on connectors and wire it up, and when you do it you will be thinking to yourself now i have bare wires in the gas? but its safe, stock 1g's have it like that, they have rubber stuff over the connections but it really doesnt keep the gas out, it will only ignite if it was vapor, which the pump is always submerged
