rforres
- 72
- Oct 1, 2002
jacksonville,
Florida
short version of my car
90 talon awd
pte 56 trim turbo, engine in machine shop now, i will have supporting mods when it all comestogether.
gm maft
dejon race fmic
maf in uicp
cold air pipe in fender well
arp fasteners
cometic head gasket
3" atr o2 elim turbo back
pte 780 injectors
zex wet kit
auto alchemy fuel system
supra pump rewired
my question only pertains to compression ratio, the cometic head gasket is .054 thick, pretty thick for a gasket, ive read that it will drop ur c/r by .3, should i go w/the 9.0 wiseco's that will be 8.7 w/the thick gasket to help spool the 56 trim or should i go w/the 8.2 wiseco piston that will be 7.9 after the thick head gasket , just the pros and cons of too much compression ration vs too little , is the higher level going to cause more knock and detonation ? harder to tune ? will 7.9 be enough ?
thx in advance.
ronnie
90 talon awd
gm maft
dejon race fmic
maf in uicp
arp fasteners
cometic head gasket
pte 780 injectors
zex wet kit
supra pump rewired
thx in advance.
ronnie
