LiquidxO2
- Dec 27, 2002
today we installed a mkiv supra smic on my 95 gsx in hopes of cooling down the charge air better. now before i did this i checked for leaks on the i/c itself TWICE and no leaks were apperent. now the first time i drove it, the air temp was around 85-90 degrees, which gave me the first impression that maybe the outside air is making it worst ( upper i/c pipe was hot to the touch, and the i/c was heat soaked). so we wait until night fall and give her 2 runs(15psi mind you). again the smic was heat soaked and the upper i/c pipe was hot. we're going to try an intake leak test tomorrow, but i'd like to hear some idea's on what else might be the problem. btw, i'm also running w/out the heat shield.
