What Injectors...
Happy
Banned Member
404
Feb 1, 2003
Will give me an upgrade?? Some say rx7 turbo ones, others say supra tt ones?? Any others out there that will fit right in and will plug up and give you more fuel?? Anyone try like mustang or corvette or something like that??
Im cheap and dont want a spend the money on new ones so i want a do it this way instead!
Or can you upgrade ur factory oness??
Fist off. What are you goals for this car:confused: From there you can decide what size injectors you want. If you lookin for 550cc injectors, then yes the 87 Rx7 turbo II injectors will work. But they have to be low impedince to drop in with no modification. If you get the high ones then you have to re-wire the resistor pack. The supra tt injectors will not work on are cars. They are side feed injectors, and ares are top feed. SO just throw that idea out the window. But if you buy any of the old RX7 injectors, then you should have them cleaned, and blue printed
