Head and timing belt
qwk98GST
Sep 3, 2002
Goldsboro, North Carolina
How hard is it to change the timing belt and head on a 2g? Also will a 1G head be better for the 2g cars? Someone let me know how long it should take to do this?
Go here to check out how to do the timming belt. Timming beltit should take you a few hours. The diffrence bettween the 1gen and 2gen head is that the 1gen head flows more its up to you if you want to do it. Youll need a few parts to get it done.
-1 Gen Intake Manifold/Gasket
-Throttle body and gaskets( May/90 and newer, 4 hose fittings on the top, 3 straight and one angled)
-New coil pack bracket 1gen
-New water pipe
- complete water neck assembly
-water line that goes under the turbo
Im sure there is a few more. GOod luck
