How do these things come out?
CBgst
582
Jun 25, 2002
I can't get the 2 head alignment dowels out of the old block. I'm really not sure what they're really called but it's the 2 little things(one on each end) in the hole where the head bolts on the end go. They align the head when you put it on the block. I've got a new block and I need to get those out of the old one. They appear to just be sitting in there but I can't get them out. I tried a pair of channel locks but they will not budge. Please help.
Carl
You need to heat the area of the block that surrounds those plugs. They are pressed in there, so you won't be able to just yank them out. If you take a torch with a VERY low flame to the area surrounding those plugs and heat the area real well you should be able to pull them out just fine.
  • For sale 255 Walbro Fuel Pump
    255 Walbro Fuel pump for 2g DSM $50.00
    • jmt2028
  • For sale 2g Coil Packs
    2g oem coil packs for sale, came of 1995 Eagle Talon Tsi $200.00Both coil packs in good...
    • jmt2028
  • For sale Spal Fans
    Spal Fans for sale11" High Flow Pusher fan $100.00 11" High Flow Pusher fan $100.00 14" Slim...
    • jmt2028
  • For sale 2g coolant resevoir
    2g oem coolant resevoir and sensor with mounting bracket. Came of 1995 Eagle Talon Tsi.
    • jmt2028
  • For sale 2g 2G DSM ECU
    Came off a 1997 GST M/T. Stock ECU
    • Stizzydrew
