motor mounts HELPPP
Eclipseturb1384
105
Dec 17, 2002
Torrington, Connecticut
how do u remove the passenger side motor mount connected to the tranny that sits next to the battery because the problem is the mount cannot get any clearance between where it mounts on the tranny and the where it mounts on the body of the car. msg back ASAP:thumb:
the four bolts the hole in the passenger wheel wall.
Take the tire off and there will be for plastic plugs full those off and you will see the bolts.
i still cant remove it, its like u have to take the tranny off just to get the thing out.
HMMMM....mine was pretty dificult to take out...cause the place where the bolts were located...there are...it takes alot of manuevering to get in there but if you need room start moving stuff....cause i had to move my UIC piping, my cables, and the battery, battery tray...and alittle squeezing...just have to keep playing with it....
hope it works out..:thumb:
