20g installation questions
civic_humper
52
Jun 9, 2002
will a 20g work with evo III exhaust manifold and evo III o2 housing? also what intake pipe work with this turbo, i have no found one yet.
also if it has a internal wastegate ive heard boost creep can be a problem but what about an o2 housing with a short dump tube?
See if your turbo dealer can perform the 34mm wastegate flapper conversion for you, this should reduce or eliminate boost creep.
The evo parts will work, you will probably need the flange on your downpipe rewelded because the angle of the evo o2 is different than the stock o2. Some people twist their flex section, but that can make your dp hit the transfer case.
