toozday22
- May 28, 2003
Hey there Diamond Star Motorsports guys...
A friend of mine has an Eclipse and frequents these forums. The other day he stated "Turbo lag is only on an automatic transmission car. A blow off valve prevents turbo lag"
I called him an idiot and told him what he needed to know. He said "tell the guys at dsmtuners.com that"...so I am.
Now I've been reading through your guys posts and have seen some pretty intelligent, in depth conversation and don't think I needs saying; but I'm saying it anyway. and if this is in the wrong forum, move it....
A turbocharger doesn't create boost immediately, which is one of the biggest disadvantages. It takes exhaust gases to get the turbine spinning, resulting in boost. I need not explain how a turbo works, I hope. Turbo lag is the time you wait for the turbo to spool up. When you step on the gas, it feels like a...well...a lag....until boost is created.
It doesn't only happen on cars with an automatic transmission. As a matter of fact, automatic transmissions are ideal for turbo applications. With a standard tranny, you let off the gas to shift. As a result of letting off the gas, you are obviously reducing engine speed and slowing the turbo. In an automatic car, you never step off the gas to shift, which reduces turbo lag. 'Good' automatic transmissions can also shift faster than the average human. Look into level-ten transmissions for some top of the line equipment.
To my knowledge, a blow off valve doesn't prevent turbo lag. It releases pressure...
To reduce turbo lag, reduce the intertia of the moving parts. This is basic physics. A turbine/compressor with less intertia will spool faster, but not achieve as high boost levels. On the other hand, a larger turbine/compressor will achieve higher boost levels, but take longer to spool because of more intertia.
Hope that cleared things up for those of you who told my friend that stuff. You guys dont seem like the type to spread information of such idiocy, but I dunno.
peace
peace
. And toozday22, welcome.
