UndergroundR32
- 664
- Jun 6, 2002
I'm curious so know everyones piston of choice is and why. Also what you think about JE.
Originally posted by NosLaser
Just about any forged piston..wait, I take that back..EVERY forged piston when installed to the proper clearances is going to get piston slap to some degree when cold. That's a pretty silly reason to discount a particular product. That aside, the Ross pistons are about the best off the shelf offering you can get.
Regards,
Regards,
JE's are a zero silicon forged piston.
Originally posted by RocketDSM
Isn't 8.5:1 stock?
Originally posted by MuttedTSiAWD
Yes on a 2G. I think it's 8:1 on a 1G.
Later,
Anyone know how fast Ross can do custom jobs? I know JE can pump out anything in about two weeks regardless of compression ratio desired.
I've never heard anything bad about JE. I was planning on using 9.3-9.5 custom pistons from JE when I do my engine rebuild. My theory on things, make a stong all motor setup and use the turbo as a quick burst on top end. Hence my higher than normal compression. Most people I talk to say to use 9.0.
Dude what are you talking about. 9:1 is nothing. That is an ideal CR for a forced motor going a third or a half a point higher is not going to get you a strong all motor car. If you want to go crazy Magnus sells 10:1 Ross pistons. I'm sure that would spool a big turbo great. However I think it would be almost impossible for the average guy to make good power on pump gas with a 10:1 or higher motor. So that pretty much makes it a race gas only car. Is that what you are looking for?
