1G Walbro 255lph, anything needed?
91AWDTurbo
Jan 12, 2003
Auburn, Washington
my pump came today, but before i put it in, do i need to change anything in order to support it? im running stock injectors for now, stock regulator, stock turbo, etc. can i just wire it in, or do i need to change anything. i know the pump is overkill for now, but i have some serious mods planned.
yeah it is overkill right now. it will also bump your fuel pressure up a lot higher as well because your stock FPR can't pass enough fuel back to the tank to keep fuel pressure down.
For now don't re-wire it because that will just make things worse. What you need to do is get an AFPR and you will be all set to run that pump.
  • For sale 4G63 MHI 20G Turbo ( Zero Miles, built by JW )
    MHI 20G Turbo $700 + shipping and paypal fees* built by Justin Whitesell * ZERO miles since...
  • For sale 2g 2G DSM Link V3
    2G DSM Link V3 $595 + shipping and paypal fees* no cable includedYou must be registered to...
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
