Turbo Dilemma
Kizmetturbodsm
Mar 6, 2003
Turbo Dilemma! (post #1)
I did a lot of researching and i had my mind set solid on a t28 Killer for my a/t GS-T. Now im hearing people saying that this turbo spools up to quick for my car and that i should go with something with a little bit more lag. My question to the a/t dsm community is what turbos are the gs-t(<--mainly) and gsx guys running and how is the traction issue? How do you like it and how does it perform? What psi are you guys running at? Also 1/4 times and dyno #'s would be of great help. Thanks in advance and all input and opinion would be greatly appreciated.
With these mods
Apexi Fmic
Full 3" n1 exhaust
3" Buschur DP
test pipe
Ported 02
Evo Manifold
Joe P Mbc
Tial BOV<-( Maybe)
Stillen 2.5" upper ic pipe ( maybe)
K&N Cone filter
650cc injectors
255wallbro pump
S-AFC
Boost / Egt gauge
Well dude, I can tell you that you don't want a really laggy turbo with an a/t. cause you tranny is going to want to shift at the lowest rpms possible all the time. So a turbo like the t28killer would be good cause they are suposed to be at full boost at 2800-3000 rpm, and hold to redline. this will be good cause when you launch an a/t you can't rev high unless you hold ebrake till launch. So it sounld be a nice turbo for you.:thumb:
Under WOT the car shifts right at 7k in first and in 2nd. Im really looking for a turbo with a lot of high end right now because in most of my races the t25 dies out in high end and other people pull liek crazy when it dies out =( But thanks for the input =) 1 point t28killer 0 point green
maybe a small 16G would be better for topend? They still spool up fast.
i would say a 20G or larger is out of the question though it would just kill your launch with an auto trans.. now if it was a 5 speed thats a WHOLE deferent story.
Personaly if you had the money i would get a 5 speed and then get a
SBR GT-12 or 20G mistu turbo.
u have any idea how hard and tedious it is to swap a m/t into that car?
Don't waste your time w/ the 28 killer, it doesn't have the top end, spools quicker than stock but runs out of steam. I have a big16g on my A/T and it just isn't enough for me anymore. I went w/ a 50 trim ball bearing unit for my next turbo, I should get it in 2 weeks I'll let you know how that turns out. I'd recommend at least a 20g for starters given you have a upgraded tranny, tc, and valve body kit. If you don't have those done stay small. Take a look at the Level 10 PTS kit and Precision Industries TC, makes a world of diff. Good Luck!!
~B
At least a 20g and install a tourqe converter
