twoboosted
- 178
- Nov 20, 2002
south,
North Carolina
Here are my dyno #'s,no fuel upgrades as you can see. This is also at 12psi.
Originally posted by twoboosted
Ok guys can you either of you give me a little more infor then this? How am I missing a 100hp?
The car is this lean on stock injectors and fuel pump.
I did those types of numbers on a 14b so regardless of trim the numbers are bad. BUT if you gave me the specs I could tell if your turbo is capable of making good power.Originally posted by twoboosted
rdrkt, is it possible that you could tell me if these are good #'s without the trim spec's?
