Greddy Type-S Help!
Mistaspakles
227
May 17, 2002
Ok I'm not sure what happened, but while I was adjusting my Greddy Type-S with the allen wrench, the pin just popped out. It doesn't seem to want to go back when I try to screw it in. It just keeps popping out. Anyone have a clue? I'm not sure if the pin is stripped or if the threads inside the bov is stripped, I need some help!!!!
you may want to try taking the purple cap off. (hold onto it the dual springs will launch it) then put the bolt back in while cap is off then hold down the springs with your hands and replace the purple cap. This way you have more surface area to apply force to other than just trying to compress those springs with the small screw.
this idea came to me while looking at the cross section area picture that can be found on dsmtalk
good luck
let us know if it works
