Need pic of 95/96 CAS!
Just so you know, 95'-96' Turbo DSM's do not have a CAS or Cam Angle sensor. You probably need pics of a 97-99 CAS. Check on RoadRace Engineering's site, I believe I saw the swap there, and they had pics. Good luck with what ever your doing.
GSXTACY
GSXTACY
yes they do...it's right behind the cam gear on the intake side...it doesn't look like a 97-99 cas, but it does have one...sorry i don't have a pic nor do i know where to find one...like gsxtacy said, your best bet maybe to check out rre's site...now that i think about, i pretty sure they had a pic on there from a long time ago...back when everyone first started putting 1g heads on 2g's...they didn't know to use the 1g cas so they were machining the 1g head to take the 95-96 cas...check it out...hope this helps...
GSXTACY
Wrong. Every DSM needs 2 signals to run: a cam position sensor signal and a crank position sensor signal. Both are needed.
In 1G CAS's, both signals come from the same unit.
In stock 95-96 cars, the cam sensor is under the intake cam gear and is triggered by a trigger plate on the gear. The crank sensor is down by the crank on the front case and is triggered by the crank trigger plate.
In stock 97-99 cars, the crank sensor is setup the same as the 95-96's, but the cam sensor is on the head in the stock 1G location. However the 97-99 cam sensors only put out a single signal, not 2 like the 1G cas's.
Yeah, on a 95-96 CAS is on the intake cam. Pretty much fills the entire wheel. I can get you a pic, but not until I go home at lunch (I took the 1G to work today to tune her up for the track tonight). If you can wait, let me know and I will get it for you.
  • For sale 2g 2G DSM ECU
    Came off a 1997 GST M/T. Stock ECU
    • Stizzydrew
  • For sale 1g 90-91 Talon pass taillight.
    Pass taillight for 90-91 Talon. Good condition. No breaks or cracks. Will buff up nice...
  • For sale 2g 2G Manual Window Assemblies, Door Panels, & Hardware
    2G Manual Window Assemblies, Door Panels, & Hardware $250 + shipping and paypal feesYou must...
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
