Phoenyx
- 222
- Nov 18, 2002
Orange County,
California
All:
Does anyone have english instructions on how to install the Super ITC???
-M
-M
Originally posted by autronicDSM
You're of unsurpassed excellence and you don't know how to install S-ITC?![]()
I don't have a 1G nor SITC but in case you wonder how you tune your car properly...well ECU takes care of timing for you. You just play with SAFC for least knock and most timing.
! If it was that easy, they wouldn't make standalone ECUs!!
Your stock ECU can control timing but only but so much. My car happens to be too advanced at certain rpms. There is no solution to this except to offset the timing. Or remap the ECU, or get a standalone.Originally posted by Phoenyx
Am I to believe that in the whole 1G population, noone had ever invested in the Super ITC??? How do you guys properly tune your cars if you have no timing control???
-M
Originally posted by LandoAWD
Don't be a smartass and bump your thread by calling people out.....if people have used it, they will answer.![]()
There - Lesson 1: A properly tuned car needs *both* timing and fuel control!
-M
HAHA what makes you think your timing is too advanced? Reason they have standalones because OEM ECUs are conservative and they have preset maps for stock car. You change your CR, cams, or anything else internal that makes power and ECU is not aware of that.
If all you want to do is offset your timing you can do it by rotating CAS.
Thanks for the lesson in tuningLet me rephrase the question then, how much timing do you see and what knock count. ECU pulls timing like a mofo when you flow too much air or you knock. Show us some numbers 'cuase I'm starting to think this is another thread of yours like one about major weakness in 4g63
Uhhh was that 44 degrees at 5600rpm or idle?
You're so damn wrong on timing. Too much or too little timing even with race gas is no good. You want your timing so you get peak torque all across rpm range. Are you sure you CAS is working properly? Maybe ecu sees something different.
17 psi on stock turbo, SMIC and 91 gas?![]()
Tell you what, YOU datalog your car and not some one else and post the f'n numbers here instead of "oh i think it was around xxx at 3600-4500". FYI, I never saw more than 38-40 degrees at idle and around 26 by 6000rpm when my car was stock.
I forgot engineers went crazy with timing on our cars.Originally posted by autronicDSM
RightI forgot engineers went crazy with timing on our cars.
which is exactly what I've said. I have a 95 and saw 26. Same as 1G according to you, but you just said you saw 19 max. What are you a troll?!?! You just gonna keep turning things around?Originally posted by autronicDSM
Tell you what, there's no way in hell your timing is too advanced. You're probbaly knocking so much that ECU can't pull enough timing so SITC won't help you in anything...good luck keeping your car from breaking. Elvis has left the building.
P.S. I saw a timing map for Lancer EVO group N rally car and at 7000 rpm under boost it was only runing 10 degrees. I was told that's when peak TQ occured.
