swordfish
- 608
- 2
- Mar 8, 2002
Ft. Smith,
Arkansas
The 7 bolt that could, no longer can. It reached the end of its life on 3/6/03. Here are some pics.
Dead 7 Bolt
jeff
Dead 7 Bolt
jeff
Originally posted by mgnficnt
how does the crank turn blue?
Originally posted by brads
Now that it walked, do you have any plans on sharing the things you tried to prevent crankwalk? I checked your webpage out, pretty interesting read. Im continuing to run a 7 bolt in mine as I build up the car, so any info on what works or doesnt work to avoid crankwalk I'd really like to see.
So what engine goes in next?
Brad
I saw you removed the 2G oil squirters, did you put 1G style ones back in? How else did you change the oil supply in the block? It looks like you did most of the stuff people claim will fix crankwalk, but it still went. How many miles were on the engine? What about the undisclosed modifications? Did any of those involve the bearings?
Brad
I'm sure you will be back better than ever. After reading your site, I guess some of your suspision was because of the quantity of oil it was consuming. Anything else?
Originally posted by NDgsx
2.4 time?
Originally posted by Violater101
What were the symptoms that you noticed before you actually spun the rod? I guess if it happens, its happens and do like you do and go with a 6 bolt. Sorry that happened to youI'm sure you will be back better than ever. After reading your site, I guess some of your suspision was because of the quantity of oil it was consuming. Anything else?
Originally posted by swordfish
Pistons will be Ross.
Do the higher compression, I really don't think knock will be as hard to control as people think. Dish pistons don't do jack for quench. Just my .02 cents worth.
.Originally posted by NDgsx
Yes 1Gs are as well, but since we have no crank sensor to hit it often goes un-noticed for very long periods of time. When you see a 92.5-94 dsm that has trouble shifting even though the clutch and hydraulics are in good shape there is usually something they're missing.
Jeff that's what I like to hear, when I build my new motor this fall/winter I'll be doing the same![]()
Originally posted by chaye
hey swordfish you mentioned something bout oil comsuption..now was it burning the oil..or was it leaking
cause mine leaks like a mother licker and bout every400 miles or so i have to add bout a quart of oil.
as of now the car is out im thinking the tbelt sliped and case tremendous idle speed sputer and stalling..wondering if mine went out too..
thanks man..
