NewB2dsm
- 910
- 4
- Jun 25, 2002
St. Louis,
Missouri
Ok.. well i did everything you can do to prevent creep on the 16g. I had a guy port my o2 and i had a 34mm wastegate flapper installed. I boosted fine, i put on my catback and it still boosted fine. Well today i put on my Downpipe, 2.5" before flex and 3" after back to 2.5" flang to fit the catback. And i went out and bam hit my 13psi and then creeped all the way to like 17-18psi before i let off. Then i turned the boost down, and i hit my 11psi then it starts to creep slow then bam all the way to 18psi in 3rd then Fuel cut. In 2nd the boost goes from 11psi to 16-17psi and my EGT temps are fine. So i get massive creep after all my precautions, 11psi to 18psi. So here are my questions HOW TO FIX IT? More porting on the O2? Bigger flapper? What
thanks
kyle
thanks
kyle
