Boost Gauge??
silva
Jan 15, 2003
I BARELY BAUGHT A BOOST GAUAGE, BUT I CANT SEEM TO MAKE THE BOOST WORK. I CAN MAKE THE VAC. PRESSURE WORK, BUT I DONT KNOW HOW TO MAKE THE SIDE FOR BOOST WORK. WERE DO I CONNECT THE TUBE FOR THE BOOST GAUAGE AT? HOW DO I INSTALL A BOOST GAUGE?
90 LASER RS TURBO
when i install the boost gauge, will it be idle around 18 in the vac. side??
is there an install guide for a 2g GS-T? with pics? the 1g looks a little different from my setup, and i dont trust myself to do it with my own knowledge.. LOL....
i just got a boost and a/f guage and need help putting them in for i am teh noob.....
Originally posted by silva
will it then go to the boost side when I step on it.?
Boost comes on around 3000 rpm, and is also load-dependent. You don't really want to see it on a lightly-loaded, or not loaded engine. Head out on a straight stretch -where you can more safely look at the gauge while driving- and romp it in third. Try it on an uphill stretch and notice the difference.
Unless you're racing and not concerned about grenading the engine, try to make a habit of not boosting in first gear.
Your car will take as good care of you as you take of it.
