Need Help.. Crankwalk starting or just clutch?
DSMTommy
138
Jan 20, 2003
Somtimes when I make a hard right turn my pedal sticks, sometimes it does while just driving..... The guy i bought the car off of filled the clutch resovior with dot 3 fluid when dot 4 is specified? any probs with that? sometimes i am driving and its like the clutch isn't moving. I push the clutch the whole way down and when i go to shift it's like the clutch is still engaged and the gears grind. could this be a problem with the fluid, the clutch, or Crankwalk (noooo). on the side, I hear no ticking or anything unordinary like the sensor getting chewed up. I appreciate the help:cry:
i am haven some problems but right now its all the way down and i cant get it into gear it sounds all bad like if i misplaced my clutch or something well i dont think its crank walk it happend after i was smashing down this street in Modesto and then a railroad came and i pulled some crazy ish of i flew up and smashed onthe ground and then from then my cluth stared to go to the ground and then i pushed it up with my hand and then later it got all stuck and i could not drive it any more! help me!
Most people who claim to have crankwalk have a bad master/slave cylinder. I had the same symptoms on my other talon when the master was going. Look under the dash at the rod that goes into your master cylinder and check to see if you see any fluid coming out.
well today i got my Pedal to work again i bleaded it i think something like that i got help from a cuz but i still leak a drop or two once ina while but i know its not fixed, bec i have done nothing to fix it so tommorow i amg oing to get it checked but thanks for the help
