DeezNutsForYou
- 282
- Oct 31, 2002
I'm trying to help my friend put a turbo on his 98 tacoma. So far we have figured a t3/t4 is going to be the best for the cost. Cheapturbo.com sells them for around $550. Anyway the problem is I don't know which setup would be the most efecient. They don't have efectiency maps of those turbo on thier site. So does anyone have any suggestions, we want to run somewhere between 7 and 12 lbs of boost. I'm note sure if we should go with a 50, 57, or 60 trim. And .48 or .63 a/r. I was thinking of this turbo, the Garrett T3/T04E 57 trim W/.48 A/R Turbine, here are the specs.
COMPRESSOR SPECS:
.60 A/R HOUSING
57 TRIM WHEEL
TURBINE SPECS:
.48 A/R HOUSING
STAGE 3 WHEEL
One more thing, is a 35mm wastegate going to be big enough.
Thanks for the help, I really appriciate it. I only wish I knew more about turbo's.
COMPRESSOR SPECS:
.60 A/R HOUSING
57 TRIM WHEEL
TURBINE SPECS:
.48 A/R HOUSING
STAGE 3 WHEEL
But if 12psi (which I think may be a bit much for a stock bottom) is the MOST you will run then something smaller will flow pretty cool air. Regardless of cfm ratings a smaller turbo willcome alive much quicker and have much more of a usable/enjoyable powerband for something like that. 2.7L is enough
and 5500rpm, I just dont think you need to go overboard.
