DSMRevolution
- 1,629
- 11
- Dec 6, 2002
Sioux Falls,
South Dakota
I read somewhere before that you can use the stock BCS along with a MBC. The MBC would be switched.
Example: You are driving around all day using the stock BCS to control boost and you pull up to a stoplight. The unsuspecting Ferrari is in the lane next to you. You think to yourself that you have no chance to win running 14psi on the stock BCS level so you flip a switch to bypass your BCS so that you can use your MBC that you already had set at 18psi. The light turns green and as your turbo spools up you pull 3 car lengths on the Ferrari. But all is lost after you hit fuel cut and the Ferrari takes the lead...
Oh, ummm sorry.
Does somebody know where the link to do this mod is at?? I can't find it anywhere. I know of the one here http://www.eclipsegsx.com/switch.htm but that doesn't use the BCS.
Any ideas? Thanks
Oh, ummm sorry.
Any ideas? Thanks
