Greddy upper & lower pipes
Romogst
71
Mar 18, 2002
I have the Greddy type S bov, now i want to buy the greddy upper and lower intercooler pipes, are they any good? Any suggestions where i should buy them from ? Is it true they give you 10 or more hp? Thanks.
Get them. I had them on my Eclipse, and they fit really well. I paid $186 shipped from www.aieonline.com You will NOT find a FULL upper AND lower ic pipe for cheaper. Hell, most don't look as good as the greddy one anyways.
I have them on my car and its not really the pipes that are you giving you the HP they help with pressure and making you turbo work less the higher you crank boost but the BOV is whats making the HP. a stock t-25 is set at 11.45 lbs but sadly the 2g stock bov leaks at like 8. so when you put the type s on and harden it up a bit it keeps your boost in and so your pushin more psi automatically.
