Does a 2.5 inch test pipe fit to the stock downpipe?
boostineklipz
1,361
Jun 2, 2002
1, Maine
I just purchased a Apex N-1 exhaust. The one with the wierd flanges since its 80mm. Well the adapter goes 80mm to 2.5 in, so I was going to use a 2.5 inch test pipe then use the stock dp intill i get some more money up for a dp. So my question is will a 2.5 inch test pipe fit to the stock downpipe?
It should cause I'm using one right now, actually I'm using it with the stock exhaust system!!!
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
