brpeclipse
- 72
- Jan 25, 2003
Chicago, IL,
Illinois
Hey guys..recently I picked up a 14b that came with the original 1g o2 housing off a '93 tsi awd; when I got home I took off the 1g 02 housing off, and RE-checked eveything...the turbo has no shaft play which is great, no oil in the turbine housing, & no visible cracks in the wastegate hole or anywhere else for that matter.
Now, I took the wastegate actuator off, and when I tried opening the wastegate flap manually, (by movng the little arm which connects to the wastegate actuator rod), it seems as if the wastegate flap is filmsy, it moves with HARDLY any effort at all. It only seals if I hold that little arm at a certain angle. Is that normal?
Secondly, (the wastegate flap), the disc seems to rotate in circles, (if I make it)..is that normal or is it supposed to be stuck in one position and not rotate?..
Thirdly, the previous owner had told me this turbo was perfect, he only took it off to install a 16g and the 14b had been laying in his garage for approx. 6months, now there is no shaft play like I mentioned earlier..BUT the comp./turbine wheel seems to move a tad slow. I mean if I move it with my finger it moves pretty easily, but doesn't stay moving for too long, is that normal? I'm guessing it's because its been laying around unused for a while.
Thanks guys...and yes, I AM getting it ported and polished (free)...
