should I buy this turbo?
92tsiawd84
213
Jan 6, 2003
Twin Cities, Minnesota
Should I buy this turbo setup on ebay @
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33742&item=2401496589&rd=1
I currently have a bushur upper ic pipe, kn filter, hallman mbc, boost guage and I plan on installing my 3" turbo back exhaust with o2 dump this friday.
Before I plan on installing the turbo, I would get 660cc injectors, a walbro 255 fuel pump, and some kind of fuel regulator (do you recommend any?).
I plan on running about 18-20 psi boost on pump gas and am looking for some where around 12 sec quarter mile times and about 300-350 hp. Thanks for your time.
I wouldn't go for it, sounds like someone cooked their turbo, trying to unload it. The picture shown there isn't actually the product they're selling. That, and a brand new 20G isn't _that_ much more than that anyway.
-Jesse
The turbo pictured is an HRC S20G. If that is whathe is claiming then that is what it looks like. I would not spend that much on one used, however. They arent worth that much used. Dont get it.wait and find a 20G cheaper, or spend a bit more for a new one.
thanks. I will pass on it then. Do you think a 20g could run 12 sec quarter mile with about 300-350 hp with a upper ic pipe, kn filter, hallman mbc, boost gauge, 3" turbo back exhaust with ported o2 dump and test pipe, 660cc injectors, walbro 255 fuel pump, and an afr? Would I need a better intercooler? Would a supra side mount work? What fuel regulator do you recommend?
