vacuum readings
kandt
151
Mar 27, 2002
iwas just wondering if anyone can help me i just bought this car and its fast but i don't think its as fast as it should be for the mods that it has, so i was suspecting that the timing was off, if you can tell me what your boost gauge reads at idle just so i have some thing to compare mine to.
mine reads around 19 cold & 21 when all is warmed up. from what i have read & researched, that is around where you want to be. if you are significantly lower, i would check your lines. i believe that there is a diagram in the back of the chiltons manual. hope i helped you out
