16g
Just after i posted it this i found the install kit for it and bushur racing. I have a mishimoto intercooler laying in the other room. Since its a from mount will i still need the piece that curves to go to the intercooler
punishment racing has all 1g parts though
The j-pipe he linked you to was because of the turbo you're buying, though. 1G's have a j-pipe stock because they have Mitsu turbos stock, but your 2G has a Garrett T25 stock which doesn't use a j-pipe. You need a j-pipe because the 16G is a Mitsu turbo and the outlet of the compressor is almost straight up. It simply bolts to the 16G and you hook your intercooler piping to it.
Just wasnt sure
thanks
Actually, that raises a good question... I know extremepsi used to sell 2 different FMIC routed j-pipes, maybe punishment's only fit the 1G.
I made the honest mistake of buying a 1G FMIC j-pipe from extremepsi and I ended up cutting a small portion of the fan shroud to get it to fit. When I called them about it they told me that their 2G j-pipe has a tighter bend to it and offered to exchange it. I'd already cut the shroud and I got the pipe installed, so I thanked them and declined their kind offer. Maybe someone else with a 2G who actually owns the punishment piece can confirm the fitment for you.
Actually that is a good point. I hadn't even thought about that. Yeah, he better ask around or talk to Punishment.
