divine dsm
- Jun 12, 2002
ok the talon is getting some kind of fuel cut or something??? heres the story... every thing use to work just fine, then my fuel pump took a crap, so i replaced it with a warlbro ( did i spell that right?) 255 fuel pump, and ever since then it doesnt matter if its at 9 psi or 18 psi i spool up @ about 3,000 rpm's reach full boost ( even at 18 psi) and then hit about 5,400 rpm and it loses power like the fuel is cutting out... WTF?? and it is only doing it since i put in a better fuel pump??? i checked the ENTIRE fuel system and fuel pressure is fine, the injectors are fine, and even re-wired the fuel pump for the higher voltage and i just can't figure this sh*t out?? some help would be much appreciated...
oh and one other thing it acts like its fuel cutting even when you rev it sitting still with no load on the motor... it does the same thing in nuetral basically...
