Poll: Karmen Readings
SlowUglyDSM
86
May 16, 2002
What's is the max karmen Hz readings you ever seen on your SAFC? Also, please specify your turbo and boost pressure...
Karmen: 1967hz
Turbo: Big 16G
Boost: 20psi
MAF: Stock unhacked 2G MAS
Hack that air can and get urself a K & N :p
People are always saying you should have better air flow with those bigger turbos :) The mod's really cheap too.
if slowugly has a '98.. he has no Aircan to hack.
highest I've seen are low 1600's on a 7cm 14b(don't Ask)
this is at 15Psi, and close to Redline....7350Rpm.... it was on my way To Work, actually.
now, as things get hotter Across the country.. *EVERYONES* karman readings Will jump. it takes more air to get the same *energy* when it's hot, and gross....
sooo if the 1900 is an older Reading... plan on it hittin 2200 before august.
2565htz on a DSM-Performance ETE32 at 6500 rpms and at 17psi. I'm sure i will se much higher as soon as I realy wind her out and up the boost but it is a new motor with 800 miles on it.
