td05-t04e
tsimiz
167
Dec 18, 2002
STAMFORD, Connecticut
i just brough a new turbo and want to know where i can get the oil and coolant fittings from? It doesn't look like the stock oil line will fit.
the car is a 1991 awd talon.
i am also looking for the the pipe to the intercooler i think it's call a j pipe where can i get this and how much?
The stock oil feed or stock oil drain?
Does it use garret oil lines?
They sell like 300 turbos. Can you give a link that's more specific please?
Originally posted by L2RTSiAWD
Looks like you could use one of the install kits for the ETE32 from www.dsm-performance.com
I would piece one together myself before I bought one of these. I was not very impressed with the "install" kit. Perhaps my expectations are too high. But, I don't like using heater hose for coolant lines when they are only 2-inches from an exhaust manifold. Oh, and I don't like the oil return consisting of two metal stubs with a section of heater hose hose-clamped in the middle.
I threw mine in the trash and spent a few extra dollars on Aeroquip stuff (I'd show some pretty pictures, but my camera is toast--maybe I'll borrow one and post some). Call me stupid, but spending another $100 on fittings and good hose beats replacing an engine when you loose all the oil on the ground and don't know it.
OMG
Heaterhose for oil return?!
Heaterhose being like the small ~1 cm Inner diameter rubber hosing?
Wow, that's crap. Water cooling lines, maybe you can get away with rubber hosing a la stock T25, but for the oil? No way.
Originally posted by cait sith
OMG
A little bigger than that. Like 1/2" or 5/8" ID, but still heater hose. I threw that stuff in the trash and ended up with Aeroquip stuff with everything sleeved in Firesleeve. I'll take some pictures soon--it's pretty! ;)
