Will A 17c Turbo Off A Typhoon Work With A Mitsu Exh Housing?
Brutus
64
Dec 20, 2002
Montgomery, Alabama
I GOT A 17C OFF A TYPHOON I OWNED YEARS AGO THAT I FOUND OVER AT MY DADS(I FORGOT I HAD THE THING) I WAS WANDERING IF IT WOULD MATE TO A MITSU EXH HOUSING? IF I REMEMBER RIGHT IT WAS A 20G INLET WHEEL WITH A GARRETT EXH WHEEL DOES ANYBODY KNOW IF IT WILL SWAP?
I do not believe it is a direct bolt up. And if its a 20g inlet wheel and a garret exhaust wheel then its not a 17c. If i remember correctly a g wheel uses 8high and 8 low blade design. A c wheel is 16 blades of the same hight. Commonly the 17c is a tdo5.
