hybridGS
- 68
- Dec 20, 2002
I have a 97 gs with an hrc super 16g turbo and full 3in exhaust. I am still running stock injectors (210's i think) but i have some larger ones i haven't put on yet. I was adjusting my boost levels to see how much i could run on the stock ones when I saw my egt basicly shoot way off the scale (scale ends at 1600) this is when the boost was set at 12psi. As i watched the a/f gauge It would run lean while boosting then would go rich when it reached full boost. I was reading somewhere that high egt temp actually has more to do with timing than mixture. I don't know if they meant engine or spark, I have an msd dis2 ignition that i haven't hooked up yet that can adjust the spark time and aem adjustable cam gears. What do i have to do to fix this problem? I dropped the boost back down to about 8psi and the temp stays below 1400.
