Shifting with MSD "stutterbox"
BoostinDSM
140
Dec 5, 2002
Utah
Who here has a stutterbox that is used while shifting? I have heard it is possible to just keep it floored while shifting with one of these. When you push in the clutch (or however you have it hooked up) rpm's drop, boost stays up. I have a MSD but can't get the hang of it. Whenever I try the rpms shoot up then drop back down. I haven't had alot of practice with it seeing as it's new. So any help would be appreciated.
Mine is hooked to the bottom one. So it's a little low for shifting I guess. When I had it hooked the the cruise switch it seemed too sensitive, mayeb I'll switch them and try it again.
Yeah the bottom switch is "opposite", so you have to wire in a seperate relay to get it to work. But I think I might switch mine to like you have it.
