KPEclipse
- 335
- 2
- Dec 14, 2003
South Jersey,
New Jersey
Alright, I need someone to say something of substance to help me, because at this point I'm compelled to sell my dsm.
Basically, about 4 or so months ago I decided to go ahead and get rid of the t25, and go ahead to the 14b. I THOUGHT I had purchased all the supporting mods, but now I'm wishing I was just happy with what I had, because this is a DISASTER
We took off all the stuff I had, and installed a FMIC, Dejon tool UICP's(for blo thru), GM MAS, MAFt, 14b, 550cc injectors, Walbro 255, EGT, SAFC.
When we first did all of that, the car would start, it just ran DANGEROUSLY hot. I'm talkin 1100 @ idle, and would climb to damn near 14, 1500 at WOT. That obviously was no good. I tried EVERYTHING with my MAFt, but just could not get it to run right. So the next thing I tried (having a 95), was the dsmchip.
On dsmchips.com I ordered a chip to compensate for everything - 550's, FMIC, Fuel pump, the works(stutterbox and all.) I put that on, and there was a slight difference. The car ran hot, but not dangerously hot...but it still wasn't RIGHT. now, it would idle around 1000, which is acceptable, but at WOT, we're back @ 1350+...no good.
The next step was to just go without the MAFt. Since the chip setup for 2g MAS and MAFt is the same, I took the GM MAS out, put a straight pipe there, and bolted my 2g MAS on the intake. Car starts, great. Car runs good at half throttle, no EGT warnings or anything, but under load, CLIMBS LIKE CRAZY. If I don't stop after every pull and hold the car at the stutterbox so that it adds fuel and the EGT's drop, my motor would've melted. Come to find out, the socket to my ECU was bad(after we buzzed it) and that had to be repaired. In the meantime, I recieve another EPROM, socketed correctly, with my chip in it, so I can drive while my original is being repaired.
Now today, I plug the replacement ECU in, and the car doesnt even TURN OVER! I can't figure it out. The ecu and chip are definately working, because when I turn the key, before I actually try to turn it ON, CEL comes on for about 10 seconds. When I try to start it, the car cranks and cranks and cranks, but won't turn over.
I am at an end of what to do, I have NO IDEA. I disconnected the battery to reset the ECU. I know the 2g MAS is working, because last week before I took the bad socket ECU out, the car was running, plus it came off of a running car. I replaced the spark plugs, swapped the wires(1&2, 3&4), but even doing that, I get nothing. Even if the wires were bad, the car should turn over, just backfire like crazy. I don't even get that, DOES ANYONE HAVE ANY IDEAS!?!?!
Please help...its been almost 6 months!
