Nitro413
- Aug 3, 2003
hey everyone
This forum is my best bet....there wasn't anything specific the non-modified parts.
so as I pulled into my driveway coming home from work today, my car stalled and a little bit of smoke came out of the drivers side of the hood, closest to the windshield.
The smoke stopped quickly, so I popped the hood and everything seemed to look alright. I started the car, and it started right up and idled fine. Went to give it some gas, the the pedal would not move....
So i pulled the throttle right at the throttle body and that worked fine.
At this point, I'm pretty stuck on what to do though. I started tracing the throttle cable back, and found it is pretty complex.
If you follow the cable from the throttle body, it loops around, and goes into a metal box mounted on the chassis to the left of the throttle body. It looks like it is some sort of pulley system; there is a cable coming into the bottom (which I assume is connected to the gas pedal) and 2 cables on the front: 1 is the one coming from the throttle itself and the other goes into a solenoid or something in front of the battery. That solenoid goes into another solenoid.
I'm not sure how to check any of these components to see if they are shot. I'm also wondering of one of the solenoids caused the smoke (which would mean the smoke traveled across the engine and came out the driver's side).
And help diagnosing would be greatly appreciated....I really don't want to start taking the throttle cable apart (i couldn't find that in the manual).
Thanks!
Thanks!
