Question about Boost Level
TurboSpyderGS_T
Dec 20, 2002
Before i even start this thread i am going to say that i did search, but i really wasn't satisfied with my results.
I just picked up a 16G w/2G install kit + $200 in trade for the BigT28 i was running. I am sure that the 16G will be more efficient than my T28, but i was wondering what would be the optimum setup. And what would be the max boost i could run on the stock SMIC. Right now i have Greddy intercooler pipes, 1G BOV, Full exhaust (2.5 inch), and a 255Lph Fuel Pump. I was wondering what boost level i would be capable of running with this setup. The injectors I have in now are the stock ones, but i am going to get another new set soon and i was wondering what size i need.
thanks alot
IIRC, the two are fairly similar in the amount of flow they can create/efficiency, so I don't know if you're going to notice a difference.
Do you have a logger? The best way to set the boost level is with a logger. If you don't have one now, you're going to need one when you get injectiors and fuel control anyway.
I would say you're safe at about 15 psi, maybe 16 psi.
thanks. I really need to get a logger, but i can't find one that i can afford right now. I could find someone close to go in together on one.
