husterka
- 43
- Apr 19, 2002
I just installed a Greddy upper and lower I/C pipe kit and a Greddy Type-S BOV. I set the adjustment screw to almost totally soft and took it for a test drive. As soon as I took off, I noticed that I was hitting almost 20psi (before it was only 13psi). I thought buy setting the screw to all the way soft would reduce the amount of boost it would hold. I did notice that the vacuum line (connected to the top nipple) is slightly loose and leaking. I think this may be the problem because it would add pressure to the top of the plate preventing it from coming open. Any other suggestions??? Thanks...
