2G clutch and fuel pump for 2g gsx
DirtyBirdRacing
762
18
Nov 25, 2002
Chicago, Illinois
What is the best clutch and fuel pump to get for a 2nd generation eclipse gsx. The car would have intake, full exhaust, cams, pulleys, B&M short shifter, cam gears, chip, and a HKS racing bypass valve. For clutches I was thinking the Centerforce dual friction clutch, and for a fuel pump I was thinking a Walbro 255lph (High Pressure) Fuel Pump. When I upgrade a fuel pump do I have to upgrade the fuel preassure regulator and injectors with it or can they stay stock, becasue I will be putting on after market turbo with electornic boost control, and I know I have to upgrade them hen, but that is not for a long time.
Thanks a lot
Skip the cam gears. Where are you getting the chip? Don’t bother with cams until you get a new turbo. And yes you will have to upgrade your FPR when you get a new pump.
Ya the mods list is kida out of order but regarless I'd get a 2100 or 2600 and walbro or supra pump.
Thanks, I think I will go with the ACT 2600 clutch. I am not sure what type of chip I am going to get. What type of chip do you suggest. FOr the list of mods that I posted on here first do you think that I would need a new fuel pump, and what is a good fuel preassure regulator to go with.
Thanks
The don't have chips or ECU reburns like for Audi's and VW's/
