02-11-2004, 08:58 AM
#1 (permalink)
Proven Member
Forward Facing Oil Filter Housing [Merged 10-8]
I am looking to use one of these with a thermostatic sandwich adapter so I can use a air to oil cooler. I have seen many post talking about them but not posts say anything about clearance on the H frame. I have a 90 oil filter housing already, I want to move the filter away from the down pipe. I do not want to use a oil filter relocation kit, just personal preference.
____________________________
Ryan
Offline
08-09-2006, 08:54 PM
#2 (permalink)
Proven Member
Region: Midwest
what oil filter housing points the filter forward!???
Okay I have searched and searched and I have seen MANY different answers to this.
I have a 90 6-bolt motor, what car used the filter housing that points the filter to the front. With the t3/t4 and 3" downpipe I DO NOT have room to even loosen the filter and it is too close for my comfort.
If you have a part # that would be even better but just the vehicle application will work too.
Offline
08-09-2006, 09:04 PM
#3 (permalink)
DSM Wiseman
Region: Midwest
Its from the Mighty Max. I beleive its part number MD016831.
Dan Kasun
93 GSX
05 Ram 1500
06 GSX-R750
Offline
08-09-2006, 09:07 PM
#4 (permalink)
Proven Member
Region: Midwest
year?? 2.4 or 2.0?
Offline
08-09-2006, 09:19 PM
#5 (permalink)
Proven Member
Car: Acura TSX
Region: SoCal
Offline
08-09-2006, 10:27 PM
#6 (permalink)
Proven Member
Region: Midwest
MD122260
there is the part # for future reference
Offline
08-09-2006, 11:23 PM
#7 (permalink)
Proven Member
Region: Rocky Mountain
I think I got mine off a elentra. They have them also I think
Offline
08-10-2006, 12:57 PM
#8 (permalink)
Proven Member
does anyone know if there is one available for 7 bolt motors? ffwd says for 6bolt motors only.
Offline
08-10-2006, 06:53 PM
#9 (permalink)
Proven Member
Region: Pacific Northwest
Couldn't you also order a filter relocation kit from jegs or summit? Maybe a dual filter kit just for kicks... Just an idea
Offline
08-10-2006, 09:12 PM
#10 (permalink)
Proven Member
Quote:
thats a good Idea I may do that if there isn't one made for 7 bolts . I cant even get my filter off with my 3'' o2 housing
Offline
08-11-2006, 08:24 AM
#11 (permalink)
Proven Member
Region: Midwest
Offline
04-21-2007, 06:46 PM
#12 (permalink)
Proven Member
Region: Tri State
Forward facing oil housing install
I was curious if anyone has ever installed a forward facing oil housing before. I know to swith the idiot sensors and stuff but what about the water line that goes to it what do i do about that, this is the one i bought.
http://www.ffwdconnection.com/filterbracket.shtml
I have the one with the optional T fitting
Offline
04-21-2007, 06:58 PM
#13 (permalink)
Proven Member
Car: 91 Colt w/4G63 swap
Region: Midwest
You are reffering to the internal water to oil cooler on your stock oil sending unit. You will have to eliminate the water to oil cooling aspect of your car's oiling system since that sending unit cannot support an external oil cooler or internal system. You can, however, fabricate an external system if you have those capabilities.
Offline
04-21-2007, 08:13 PM
#14 (permalink)
Proven Member
Region: Tri State
So what you saying is just block off the cooling line or fab it up so i can still use it
Offline
04-23-2007, 05:23 PM
#15 (permalink)
Proven Member
Region: Midwest
Well, if you block it off then you have absolutely no oil cooling on your turbo charged engine. It is a better idea to fab up a way for your engine to have an oil cooler.
Offline
04-23-2007, 09:25 PM
#16 (permalink)
Proven Member
Region: Tri State
Has anyone ever fabed up a way to still use the line if post it up be greatly appreciated
Offline
04-24-2007, 09:28 AM
#17 (permalink)
Proven Member
Region: Southeast
Throw the Water to Oil Cooler away & blank the Coolant Lines - from those pix it's not gonna fit on the Oil Filter Bolt anyway - & yes get an Air Cooled Oil Filter.
Offline
01-24-2008, 02:59 PM
#19 (permalink)
Proven Member
Region: Southeast
Forward Facing Oil Filter Housing Part #?
Hey guys, can any of you confirm the part # is MD122260? Someone said they thought this was it. Thanks a lot.
Offline
01-24-2008, 03:11 PM
#20 (permalink)
Proven Member
Eric
Offline
01-24-2008, 03:33 PM
#21 (permalink)
Proven Member
-Grant
Offline
01-29-2008, 02:12 PM
#22 (permalink)
Proven Member
Region: Southeast
How to hook up oil cooler to forward facing oil filter housing?
Hey guys. I was considering getting a forward facing oil filter housing for my new 6 bolt swap. I'll be using a sandwich adapter in between the housing and oil filter and I don't want to worry about downpipe clearance. Only thing is I hear how you can't do external cooling with them?! Is this true or is there any way to accomplish it? Here's a pic if anyone can take a minute with it and MS paint and possibly illustrate it for me and anyone else out there. Thanks.
Offline
