red clipse
- 41
- Nov 21, 2002
nuggetville,
Australia
Can I use an install kit from a 16g on my L2R?
Originally posted by KenTSIII
You shouldn't need an install kit. Just use AGP's oil feed line, a 1g oil return line & water lines.
NO. The turbo outlet pipe is different for a 16g. You will need either a 90deg elbow welded onto the L2R turbo outlet with the appropriate intercooler pipe to match it or get a 20g outlet to intercooler pipe. Everything else (oil line, coolant hoses/pipes) should work.Originally posted by red clipse
I know AGP gives you the K&N filter to put onto their braided SS oil feed line, but does it use the standard 2G routing or does it come from the head like a 1G? If the latter, then why? How about the oil return?Originally posted by KenTSIII
It comes off the head. The reason for this is because the oil pressure at the head is less than at the oil pump/filter housing. The Garrett ball bearing center section can't hold more than 60psi according to AGP. Oil pressure at the pump/filter housing can go well over 100psi on start-up. Oil return is the normal Mitsu type.Originally posted by doug
