link how to tap boost gauge for 2g?
96TalonAWD
224
May 3, 2002
Orlando, Florida
hi ima trying to tap it to my fuel pressure solenoid but i dont know the exact location and hose can somebody help?
i already got that link but there he tap in the Tbody i hear the FPR is the most accurate tap. thats where i am trying to do it. where did you tap?
The boost gauge tap needs a feed from a source off of the Intake manifold. You want to see exactly what boost level is reaching the cylinders. The FPS source is a perfectly good place to set the source AND its on the drivers side firewall so its close as well.
Look at the Fuel pressure regulator at the end of the fuel rail. There are 2 lines coming off of it: a return line for fuel and a vaccum line. Follow the vac line up to the fuel pressure solenoid. This has 2 vac lines attached to it: 1 is the one you just followed, the other leads to the intake manifold. You want to tap into the line that leads to the intake manifold to get your boost gauge source. Best way is to cut the line and 'T' it with a plastic hose T connector. attach your source line to the boost gauge to the T connector and make sure all 3 attachment points are snug.
